If you remove your chimney or stove cap you will cease having creosote build up and most likely never have a creosote fire.
The reason for this is the hot gases and smoke that exit the pipe can now exit much faster and freely therefore not allowing the back up of smoke within the pipe..........which in turn allows the smoke/moisture time to adhere to the walls of the pipe, resulting in moisture or creosote.
I was just told this story by a friend of mine, that was told this by an old timer who burned for many years. He also stated at the time he had just had a chimney fire and the old timer told him to remove his cap and he would never have any problems again.
The owner has never had a chimney fire since he followed the old timers advice, and he said his pipe has not been cleaned in many years. His pipe was checked in the last couple years and he said it was still perfectly slick and clean from top to bottom.
In my opinion this is worth a try, except for those who has a pipe that runs directly into the stove. I am fortunate to have my pipe run in to a clean out and don't think the rain could travel to my stove from the cleanout.
During the summer, I would probably make a cover like an old stainless pot to be easily removed for fall burning.
Thoughts ?
Robbie
Thoughts ?
Robbie
