I'm thinking about fabricating and welding my manifold for my secondary loops instead of using a bunch of tees and nipples.
I would use a piece of 1-1/4" pipe and weld forged 1" connectors to the pipe. Then I would use forged 90* elbows for the turns. Each end of the manifold would be threaded so I could attach it the supply/return using unions.
Before install I would pressure test at like 50lbs for a 24 hrs....or something like that.
Anyone ever weld out manifold? Anyone see any reasons not to go this route? Only issue I can think of is the drilled hole & welded connector won't have as a smooth transition as a tee. Does that even matter?
Edit: This is for an open system(Garn 2000)
Thanks![Fabricating a manifold for my secondary loops. Fabricating a manifold for my secondary loops.](https://www.hearth.com/talk/data/attachments/200/200212-2c1699423e4daa9bef22bac685cdb33e.jpg)
![Fabricating a manifold for my secondary loops. Fabricating a manifold for my secondary loops.](https://www.hearth.com/talk/data/attachments/200/200213-12d7dc9fc79fd6edcaa721c5b7c9d1e1.jpg)
Sent from my SM-G950U using Tapatalk
Thanks
