Trying to learn the stove and seeing what would happen if I tried to shut it down all the way. Has been cruising around 350 stove top with catalyst listed in the mid way point. Had it up to 550F on startup. Is there a limit on how low I should try to run? Fan is being a bit temper mental. When I first tried it it would turn on fairly easily and then shut off and back on again. Now it does not want to seem to come on while the stove is running, only while the stove is cooling down. I'm getting I should look into replacing the snap disk.
![[Hearth.com] F3500 cruising on low? 350F stove top temp, no smoke out of stack? [Hearth.com] F3500 cruising on low? 350F stove top temp, no smoke out of stack?](https://www.hearth.com/talk/data/attachments/318/318644-00922e8eed421e9d1f3302f60c708783.jpg?hash=CTB5006WK5)
![[Hearth.com] F3500 cruising on low? 350F stove top temp, no smoke out of stack? [Hearth.com] F3500 cruising on low? 350F stove top temp, no smoke out of stack?](https://www.hearth.com/talk/data/attachments/318/318660-43af7074e95aa4e54d13d258af5173af.jpg?hash=X7oBpxT7bj)
![[Hearth.com] F3500 cruising on low? 350F stove top temp, no smoke out of stack? [Hearth.com] F3500 cruising on low? 350F stove top temp, no smoke out of stack?](https://www.hearth.com/talk/data/attachments/318/318661-d31ac14c65e2c8393e289ab86de84f8f.jpg?hash=9bPwE3zLqO)
