Hello all, thanks for the help here in the past!
After installing my stove and chimney last year, I'm still struggling a bit with one aspect: I can't turn down the primary air very far and still maintain flames. Maybe the best I've been able to do is 2/3 of the way down..in stages, hot stove, etc etc,.... and I read about others cutting primary air quite a bit more in their stoves. This leads to overheating inside once our place is up to temp.
After finding a clogged chimney screen late last burning season, I thought some of my issues were that. But this year, I cleaned the chimney, cleaned the chimney screen, using some kiln dried wood, verified properly with a moisture meter, and I still have the issue. I'm starting to wonder if I need more draft and thus chimney height?
Specs on the install: Jotul F100 installed last year in a 520 SF single story cabin. Running the stove with the long leg kit, rear exit into a tee, into double wall stove pipe, straight up to the chimney.
Chimney is Selkirk Supervent. I've got 8 feet of chimney which starts 8 feet off the slab floor of the cabin. So there's about 6+feet of stove pipe, and 8 feet of chimney.
Jotul's manuals mention a "14 ft minimum" chimney, but never specify if this is from the floor or from the stove exit. From the floor, I have 16 feet to the top of the pipe, or about 14 1/2 feet from the stove exit.
Here's a few pics for reference:
Thoughts? Could this be my issue, that the stove doesn't pull enough air due to the chimney length? Since I already have the chimney braced, holes in the roof for that, etc....I'm resistant to add ANY more than I NEED... Do you think adding 1 foot would make any discernable difference? Should I add a 2 foot section? Or is there something else I should be looking at?
Thanks!
![F100 Should I add chimney height? F100 Should I add chimney height?](/talk/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FELFwPyZ.jpg&hash=d88a0717254f074f43f8052a4739ef79)
![F100 Should I add chimney height? F100 Should I add chimney height?](/talk/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FHOL3wK2.jpg%3F1&hash=c177f9a9cd4dc7a81f4e5dc0f8152e48)
![F100 Should I add chimney height? F100 Should I add chimney height?](/talk/proxy.php?image=https%3A%2F%2Fi.imgur.com%2Fuu3hJLG.jpg&hash=9be73e3276aeb6bb9fd85049e44d261e)
Thanks!
