Hi,
I have a wood masonry fireplace (built in the 50s) that is on the exterior wall. The fireplace is on the first floor of a two story (1 1/2 cap cod) house. The fireplace the highest point of the house. The hearth is always cold and when I open the damper there is a downdraft. I've tried building a fire a few times and I always get smoke in the house. Granted I am new to fireplaces so I may not be doing it right.
I had the fireplace cleaned and the sweepers mentioned that the fireplace looked like it was hardly ever used. So I believe the previous owners of the house always had this problem and just didn't use the fireplace. They were the original owners of a 1950s house. So it is kind of hard to believe they lived so many years with such a problem. Anyhow, I moved in and now it is my problem.
I had one chimney company come in and they said it was a downdraft problem, probably wind hitting a building or something and coming down the chimney. There is a house within about 12 feet of the chimney that is a mirror of my house and a few feet higher. They didn't look to see if there were any buildings close by, so I got the feeling they were just guessing. Anyhow, they suggested a vacu stack. They said it stops air from coming into the chimney opening. They said they could do it for $1200. They didn't mention anything about the exterior chimney being a problem.
So my questions are, with an old exterior masonry fireplace, the fireplace is always going to be colder than the inside of the house. And the fireplace is below the halfway point of the house. Does that mean that air will always flow from outside to inside (as explained in http://www.gulland.ca/fhs/coldhearth.htm)? Would a vacu stack solve this dynamic at all? Is there a better solution? Or should I just follow the wisdom of the previous owners and never use this fireplace? In that case I would put one of those fireplace baloons to stop the air from coming in.
