- Dec 12, 2012
- 3
I found a small wood stove for my trout cabin. It is very old and there arent any real resources online for things like this. Its a fairly common design, I believe its known as a laundry stove. It seems to be missing a bottom section. I think its supposed to sit higher up off the ground maybe with some small decorative feet or something. What would you suggest I use instead? Also it seems to have a 8" exhaust pipe fitting. Does that seems too large, could it be down graded to 6 or 4? Its missing the flue piece as well(if it ever had one) do I need one of those? In such a small place(8'x12' cabin) should I add a small fresh air inlet near the stove? Do you suggest side or vertical shaft for the exhaust? Lastly, do you put an ash pan in the bottom or just use a little shovel when it gets full? If so what material do you make an ash pan out of? Sorry about so many question but I needed the help ![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
![Expert advice needed about older stove installation Expert advice needed about older stove installation](https://www.hearth.com/talk/data/attachments/84/84845-f362d7dd02e6348aa61ea71ff8cc9d35.jpg)
![Expert advice needed about older stove installation Expert advice needed about older stove installation](https://www.hearth.com/talk/data/attachments/84/84846-67d3daaed9ae4aaac8095f4f3f0a43f6.jpg)
![Expert advice needed about older stove installation Expert advice needed about older stove installation](https://www.hearth.com/talk/data/attachments/84/84847-d4b24b3f27f295d1f57b234b0b17d823.jpg)
the boot is a size 12 16in tall muck boot for a size reference. Thought that might be needed for exhaust pipe size. Thanks for any advice you can give me.
![Expert advice needed about older stove installation Expert advice needed about older stove installation](https://www.hearth.com/talk/data/attachments/84/84848-8e95d68d434345780f88bf006a51397e.jpg)
