Hi,
I should first ask for clarification regarding the concerns I see here regarding Flue Temps / Cap temps / Exit temp, or any other temps after gases have left the stove (I hear flue, chimney, and exit temps being used interchangeably, although I'm sure distance from the stove is important -- cap temps I assume being the end).
I assume this is important for keeping creosote buildup down and for making sure you get the draw needed for your specific chimney situation (location, length..). Please add to my understanding if it's more than that.
But it appears these concerns may also depend on the type of stove and how well the stove is able to fully burn material? For instance I believe I've read some Masonry Stoves, Russian Stoves, & Rocket Mass Heater Stoves intentionally have lower exit gas temperatures. I know certain designs claim to burn the fuel much more efficiently -- because of higher internal temperatures in combustion chambers where all the gases are burnt. Those hot gasses are then used to heat the large masses surrounding the route the gases take to escape.
The FlueGuard thermometer I have above my more traditional though EPA certified Green Mountain 60 appears to indicate around 375 degrees is the minimum for "optimal operation". But I assume this EPA stove similarly is able to fully burn the gases as it passed through my catalyst. I am fully double walled once leaving the stove, but considering complete combustion, couldn't I have lower temperatures exiting? Or, could I have had single wall directly above my stove to allow more heat to transfer into my living space (and then transfer to double wall)?
Is the reason Masonry and Rocket Mass Heaters allow for lower exit temps simply because they ensure the complete combustion?
