I am putting a P68 in the basement with a T and then vertical pipe for better drafting. The OAK is also being installed. The basement is a walkout and the install wall is the only side not cement and not below grade.
Question is this (hope it is not asked here too often, but I am sure it has: I just cant find the thread). Should I put the T and vertical inside or outside. I have received conflicting recommendations from dealers. I realize that the T inside wil mean cleaning inside, but it has also been pointed out that this setup allows for an easier (although dirtier inside)cleaning mid winter if needed.
Also concerned about snow cover in that area of the house. This side can get some deep snow at times, but not really a side that drifts. It has been pointed out that there would not be any snow in that area due to the exhaust heat, but over the past few winters there have been too many deaths in the neighboring states due to furnace direct vents being covered over by snow drifts.
Any suggestions on either setup?
Thanks !!
Thanks !!
