Exhaust Liner Adapter help!
PutnamJct
Hey All,
I am doing a full flex pipe reline and ran into a snag.
Original exhaust was 3" and I am going to 4". Nothing that came in my reline kit is even remotely close to fitting, they are all way too big in diameter on the stove end. I have to use the original Quadrafire flange to connect to back of stove.
I found this at home depot:
http://eandata.com/lookup/0050206925522/
Picture here:
[Hearth.com] Exhaust Liner Adapter help!
It is 26 gauge galvanized steel and would fit perfectly, however I do not know if I can use this for pellet exhaust.
Thoughts?
Thanks,
John
I would not use this galvanized adapter as it will cause bi-metallic electrolysis. Others have taken the piece that will work to your local exhaust system shop and have it fabricated. I am surprised Quad doesn't offer an adapter. Good luck!
(broken link removed to http://www.stove-parts-unlimited.com/Quadrafire-1200i-Top-Vent-Adapter-4-p/811-0670.htm)
perhaps one of these?
I saw that one, but what's odd is my clamps are on the stove, the one in this link has them on the flange......weird
Your right. Mine too. Call them and asked them.
This is what I am trying to connect 4" pipe to:
The diameter of this is slightly less then 3"
Could look at this as well. It is made for pellet stoves
(broken link removed to http://www.hardwarestore.com/pellet-stove-pipe-increaser-121694.aspx)
That looks like it could work...good find!
