Exhaust Fan
dbarcon
16
Arizona
We have an older model (1999) Quadra Fire Classic Bay. It runs great! The problem we recently started having is with the exhaust/combustion fan not shutting off. It is sporadic also. When the unit calls for heat all goes well, shuts off when room temp is reached except that the exhaust will sometimes continue running for hours and sometimes it shuts off when it is supposed to. Sometimes it comes on all by itself when the unit is not even calling for heat, then for whatever it will just shut off. It is very strange?? Anyone have any idea what might be going on?
Has the stove been plugged into a surge protector? If not it may have been affected by a power surge and damaged the control board.
Reactions: kappel15
Either the motor is bad, or the control box is bad. Betting on control box. Do you know someone that has same stove as you, you can put your box in to check it out. Or is there a dealer close that can test it for you? And remember to always unplug stove before removing or installing a control box, or you run the risk of toasting them. kap
Reactions: Ssyko
