been redoing the exhaust on my stove since the person who installed it(previous owner) did not use RTV or screws on it..just put the pipes together.
this is the kind of pipes that were used
http://www.menards.com/main/heating...2-ez-adjust-length-black/p-1323184-c-6893.htm
he used two 12" pipes and they connect together inside the wall thimble so i was unaware it was two pipes until i just pulled the pipes out. should i just try to RTV the pipes and make it work or should i just trash it and by a single longer pipe?
problem im having is the pipes connect INSIDE the wall thimble so if i RTV the pipes together and use screws they will not slide through the thimble opening with out cutting the opening where the screw heads are. the twist lock pipes form HD look handy. They do offer the same brand pipe i have at menards in a 5' length but its $50 and for that i could get a 2' one from HD and a adapter with the twist lock?
