I have a Yankee pellet stove and the exhaust blower shuts down for apparent reason while stove is running. anyone have any suggestions as to why ? My stove is 10 years old and I am thinking it's the control board.
Glad you're running now! Was the pipe really badly clogged? I'm trying to figure out why the motor was stopping - I'm now guessing that the back pressure overworked the motor and it overheated...maybe.
Sounds like Lake Girl was right - loss of vacuum to the switch caused a shutdown. But, AFAIK, that would only stop the auger motor, not the combustion blower, as you would still need to exhaust the smoke. Curious...
I didn't see what lake girl posted, this site for me is wicked hard to navigate.
Pressure switch might have been tripping if it couldn't exhaust enough air. Was the auger shutting down too?
Is the stove on a surge protector and have you had power outages/fluctuations lately? Would be a good indicator if it was the board...
Welcome to the forum!
Surge protection is important as long as it is plugged in ... doesn't need to be operating. Many stove operation problems can often be traced to maintenance not being performed as it should. We'll cut you some slack 'cause you're a newbieMost stoves need a deep clean after about a ton of pellets... that means internal exhaust paths and exhaust venting, cleaning blowers (both but exhaust blowers need new gaskets usually). Search leaf blower trick ... if you choose to use this method remember to disconnect the vac switch!
Manual in case you don't have one: http://www.lopistoves.com/travisdocs/100-01156.pdf
Does liner run up to the top of the chimney? Leaf blower trick won't work if it doesn't. Close neighbours may freak with the black cloud that forms too... better for rural applications!
When you cleaned the stove, did you remove the back wall of the firebox (page 34 of the Manual), the vertical exhaust with ports on each side behind the side panels (gaskets needed), and the exhaust blower (gasket needed there too)? I use a dryer lint brush on my vertical exhaust pathways and follow up with a tube snaked up there attached to shop vac attachment (use drywall bag for shop vac but make sure ash is cold).
Might also want to check door gasket...dollar bill test. Dollar or similar paper shut in door. If it can be removed easily, time to replace gaskets.
