I woke to a horrible sound this morning. My combustion blower was howling, like it did when cold, but usually cleared after getting hot. I took the blower out. I WD40'd and used compessed air and scraped and Qtipped everything and then I took aprart the blower. Need special tools here, Torx wrenches. Bearings FEEL bad. Should be smoother, but feels bumpy, hard to describe. Flooded bearings w/ WD40, re-assembled, bearings feel much better, and installed, amazing decrease in sound level (yeah
!!) suspect this will be a short fix due to high temp and volatility of lube. I am assuming these sealed bearings absorbed some lube. Please advise. Also, noticed some slight abrasion by outside fan on combustion blower that appeared to be causing some noise. This fan, which is pressed onto the shaft, can move on the shaft, hitting the housing on either side. This may have been the loud noise on cold start- the position of the external cooling fan on the shaft may have shifted as the length of the shaft expanded during warm up, causing the fan to move away from the housing enough to clear it.
