Excessive Vapor/Moisture In DV Gas Stove Pipe
Mr Frugal
14
I recently installed a Enviro Ascot direct vent gas gas stove in my basement. Everything is hunky dory, except for one issue: water condensation leaking from the exhaust pipe.
I've used ICC ExcelDirect 5" piping, 4.5' up, then a 90 degree out through the wall.
What is happening is, when the stove is off, (with the pilot either on or off), then turned back on, water will run out of the inside of the 90 elbow once the stove is relighted.
Obviously I have an air leak somewhere that is causing warm moist air to condensate and freeze on the inside of the pipe(s). When the piping warms, the ice melts and runs out the joint.
The trouble is, I can't figure out where it's leaking. Initially I thought it was being caused by the lack of good seal on the exterior of the pipe at the stove. (It being the lowest, and best point for convection to take place from.) I slathered on the RTV on that joint, but it did nothing.
We've had some rather frigid nights here in southern Ontario (-28C ) the last little while, so the condensation has been rather voluminous.
Has any one experienced this, and do you have any suggestions as to how to remedy this? I'm to the point where I want to disassemble the piping and coat all the joints, inside and out with RTV....
  • Excessive Vapor/Moisture In DV Gas Stove Pipe
You're looking in the wrong area.
Your "air leak" is called a cap.
Look out side the house to see what's getting in...
I'm not quite sure what you mean. I have a proper termination cap on the exterior. The only way I could see the termination cap causing issue this would be if some how warm, moist exhaust was being pulled back into the pipe. The design of the cap is such that it seems unlikely this would happen.
Also, since the frost/moisture build up is happening whether the pilot is lit or not leads me to believe this is not the case.
Looks to me like the icicles are coming out of the intake on the cap.
It also looks like your cap is too close to the ground,
but I don't know what the snow depth is...
There should be AT LEAST a foot between the cap & the ground.
Get those icicles out of the intake & I'll bet your leaks go away.
Can't hurt to clear away the snow below the cap as well...
I'm thinkin that due to the proximity of the snow, when the heat generated by the
DV cap is stopped, you're getting condensation & icicles as a result.
Get em outta there.
Here's the manual:
http://www.enviro.com/images/manuals-brochures/owners-manuals/C-11277 Instruction Ascot Owner's Manual.pdf
Page 14 shows the clearance to grade.
As an aside, you sure you're using 5" vent & not 4"?
No, the ice is forming on the outer side of the intake shield, on the exhaust side. I'll knock them off, but I doubt that's where the problem is. It was happening in early December, before we had any snow, and before the cold snap that has caused this ice build up.
The cap is 18" above ground. I'm keeping an eye on the snow build up. We had a storm with high winds out of an unusual direction that caused this uncharacteristic build up. I may have to install a window well underneath the cap just to be safe, but I'll do that in warmer weather
I'm using a 5" vent, as per my local Enviro dealer's specs.
I still think it's the friction fit of the external pipe that causing it. It's not airtight, and warm air is leaking in and convecting upwards and condensing on the cold parts of the intake. Either that or the seal on the exhaust somewhere near the cap is bad, and is leaking moist air into the intake. Although, since the condensation is happening whether the pilot is on or not, leads me to believe it's not the latter.
Totally normal - its just due to the fact that you have an exterior vented cap that is letting in all kinds of cold air (especially when the stove isn't running). Cold air hits the nice warm air inside the pipe within the building envelope and condenses. I always have a small drip on my horizontal section right where it comes thru the thimble into the house. I'm also in Ontario and have the same temps as you. I wouldn't worry about it.
This is a bit more than a drip. It's more like 10-20cc once the stove heats up. I'm also of the 'no moisture is good moisture' mindset. I've done enough reno's to know what damage small drips over long periods of time can do to buildings. Right now I just have a wad of paper towels sitting on the floor to intercept the runoff when the stove is fired. I'm also concerned about the possible corrosion of the pipe. If it was all stainless, I'd be less so. I'm not even sure if it's galvanized on the inside.
