I've bought the Englander add-on furnace, and while I do a bit more remodelling/additions to the house, I need to run it as a stand-alone for a year or two. (Don't bother telling me it will heat best when married to an existing forced air furnace...I know that already
). My question is, can anyone give me the air-temp range for the outlet air, at full burn as well as, say, mid-point through a burn cycle. I know if will by very variable, depending on fuel conditions and more, but I'm just trying to get an idea.
For now, I'll have a 8' run of 8" pipe, then an 8" T, then 2, 6' or so runs of 6" pipe to 2 difference sections of the house (2 6" runs will give me just a hair more cross-sectional area than the 8" outlet, so I should be in good shape). I'd rather keep the air heated, rather than the air around the duct (mostly utility room area which will get plenty hot from the furnace itself), so one of my decisions is whether to insulate the ducts or not, and I also wonder if the air temp is too high for insulated flexible ducting.
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
