We are the proud owners of (apart from our Jotul F600) an Esse WN kitchen range wood burner. We lit up this unit for the first time two weeks ago, and generally it has been great - the kitchen has been warm, and it cooks fabulously.
![Esse wood fired kitchen range -a problem Esse wood fired kitchen range -a problem](https://www.hearth.com/talk/attachments/4059336424_643d4b3c64-jpg.181005/)
However, occasionally we are experiencing what can only be described as a muffled explosion from the firebox, the unit rattles, the hotplate appears to lift, and smoke and soot belches out from around the edges of the hotplate. This is alarming, and frightens the cats, the wife, and me! I am guessing that unburnt gases in the firebox are igniting suddenly, and the increase of pressure cannot be handled by the flue - but it is only a guess. It has been suggested that this may be due to downdraughts in the flue, although when it happens it is irrespective of windspeed and direction - indeed it has been dead calm on one occasion.
The Esse is installed in a single storey kitchen, where there wasn't initially a chimney. We have built one of earthenware segments designed for the purpose, and it terminates at about ridge level (about 20 feet from ground level). The flue is single-walled Poujoulat (French flue specialist) stainless steel flexible tube, which passes into a 45 degree "T" piece with a rodding cover. The flue itself is insulated between the stainless-steel tube, and the walls of the earthenware segments with rockwool Flacon loose fill. The flue then passes through a 12" stone wall, and a 45 degree bend (with access cover) returns it to the vertical, and thence into the cooker via the oven damper. All internal flue parts are black gloss enamelled, and single wall.
The flue draws well, the fire burns hot, and is fairly controllable via air controls and an oven flue damper. Our wood is a mixture which I trim to 40 cm logs, seasoned for about 3 years, and dry - the moisture content is quite low. We use the same wood on the Jotul without problems (but 50 cm lengths).
I have removed, cleaned and examined the hotplate unit, which is held on the stove by screws passing into brass "H" blocks, supported by a fork either side on the cooker body. One of these "H" blocks is badly deformed (see photos) compared with its partner. The damage suggests considerable stress, and is in keeping with high momentary pressure from below - this could support my theory of an explosion. I can't honestly see any other way this component could suffer such catastrophic damage.
![Esse wood fired kitchen range -a problem Esse wood fired kitchen range -a problem](https://www.hearth.com/talk/attachments/4059336190_0ea32b083c-jpg.181006/)
![Esse wood fired kitchen range -a problem Esse wood fired kitchen range -a problem](https://www.hearth.com/talk/attachments/4058592795_3404b9e509-jpg.181007/)
![Esse wood fired kitchen range -a problem Esse wood fired kitchen range -a problem](https://www.hearth.com/talk/attachments/4058592511_4860ccb00f-jpg.181008/)
Has anyone any ideas supporting or refuting my feelings about this?
I have contacted Esse, who are sending new "H" blocks, but who are reluctant to enter into correspondence concerning the possible cause of this phenomenon, and the possible safety implications involved. I could really do with a second opinion, and will give further information if required.
Esse are a British company, and the foundry has been making this type of range since 1854, and compare favourably with the likes of AGA or Rayburn. However, their customer service has been reportedly poor, an experience with which I concur.
Thanks
Chris
Thanks
Chris
