I've got a 2005 Accentra that has not been keeping temperature like it used to. I normally keep the thermostat at 65-68 degrees in room temp mode but lately it starts going bananas and will keep heating wide open until I turn it down to 60. It seems to work ok if I keep the temp setting at 60 but that's somewhat cold. I did replace the potentiometers on the main board but that didn't seem to help.
I do notice when it's cranking away and I unplug the air temp probe the distribution blower will stop. Could I have a bad air temp probe? I would think I should be able to do a resistance check to it at various temperatures to see if it's going bad. Does anyone know what the values should be at certain temps?
Any other ideas?
Thanks.
Any other ideas?
Thanks.
