have had my accentra insert for several years and have always experienced the following.
1. my flame rises to 8-10" fan while the auger is feeding. it will then burn down to a small 1 -2" flame until the auger kicks in again. it repeats this over and over. have adjusted every thing . dosn't matter if the feed rate is 3 or 6, if temp or fan controls are on low or max. it goes back and forth from max burn to minimum burn. it is the most dramatic in the room temp mode. stove temp mode is less dramatic. on the surface it appears there is a delay in the auger.
2. the auger never,never fills the burnpot 1" from the edge and never overflows. the burnline is always 2-3" or more from the edge. the ashes build up along this burnline and result in a carbon buildup daily. some mornings, depending on pellet brand, it looks like a birdsnest in the burnpot from the buildup of ash. control settings do not affect this daily occurance.
dealership replaced the control panel circutboard, no difference. door gasket is fine, pressure is plentiful. probe,flap and chambers are cleaned monthly.
