I do not open the ash door to start a fire but I burn mine 24/7 and from time to time I open it long enough to pull out ash tray to empty. Is this ok to do or do i need to let stove go out every time i need to empty ash tray.Hi Detour,
Welcome to the forum.
Are you talking about the grate in the bottom of the stove that lets ashes fall into an ash pan? If so, the fist question everyone will ask you is, "Are you opening the ash pan door to start your fires?" If you are, then that is the likely cause of the grate cracking. If you aren't, then you should check to make sure the ash pan door gasket is in place and is in good shape. Air coming in through the ash pan door by cracking it or a worn out or missing gasket causes a blast furnace effect that can not only damage the grate, but also damage the floor of the stove, which an expensive fix. Good Luck.
Ok Thanks ! If I buy another grate I will try that next time.I don't wait for the a cold stove to empty my ash pan, rather I do it in the morning before I reload when there are just coals in the stove. A good tip someone gave me is to crack the main stove door when you do this and you will eliminate the blast furnace effect of air rushing in through the grate when you open the ash pan door.
