I live in Ireland and have owned an Enviro Windsor pellet stove since around 2007. I have replaced the igniter a couple of times myself and have had no other problems with the stove until recently. Currently, however, the stove won't light. When the on/off button is pressed, the combustion motor runs for about 15 seconds and then stops and light 2 on the heat output bar flashes. I have some DIY experience but am not very comfortable with electrical issues and would be very pleased to receive some advice as there are few of these stoves in this country and the firm that sold it no longer exists.
The Trouble shooting manual states (I have put my findings at the end of each point)
Light # 2 on Heat output bar flashing
(The Vacuum Switch contacts have opened for more than 15 sec.)
To reset Circuit Board after a trouble code - push the ON/OFF button.
Many thanks in advance for your suggestions.
Marcas
- Pinch, break or blockage in vacuum hose - check hose for pinch points or damage, replace or re-route as required. Blow out vacuum hose - Have done this. hose appears to be in perfect condition
- Blocked hose barb on exhaust channel - use a paper clip to clean out hose barb or remove the vacuum hose from the vacuum switch and blow into the hose to remove blockage. Have blown through hose after removing the vacuum switch end and it appears clear.
- Blocked exhaust / venting system - have stove and venting cleaned and inspected. I disconnected the flue pipe temporarily to see if this made any difference and it didn't.
- Severe negative pressure in area where unit is installed - check the operation by opening a window, does this solve the problem? If it does, install fresh air intake to unit or room. Venting system may require vertical section to move termination into a low pressure zone. Not an issue
- Vacuum switch failure - bypass the vacuum switch, if this corrects the problem check for above problems before replacing the vacuum switch. Not sure if I did this correctly - I ran a wire to connect the two wires going to the vacuum switch but this had no effect.
- Damage to gray wires between circuit board and vacuum switch - inspect wires and connectors. These appear to be in order.
- Combustion blower failure - the combustion blower is not turning fast enough to generate the proper vacuum in the exhaust channel. Visual check; is the blower motor turning? Check the exhaust blower voltage across the blower wires (>=220V on #5 setting and >= 165V on #1 setting). – Replace the Circuit Board if the Voltage reading is less than 160V. with a line voltage >220V AC. Not quite sure if I did this correctly. There were two wires coming from the circuit board which connected to two other wires from the combustion blower. I disconnected these and connected a voltmeter to the side coming from the circuit board. I got a reading of 240 volts for about 15 seconds and then the voltage dropped to zero.
- Check vacuum levels in the exhaust channel by bypassing the vacuum switch, then remove the Vacuum hose from Vacuum Switch. Check exhaust vacuum readings by placing the open end of the Vacuum Hose on a Magnahelic Gauge. (readings must be above .10" W.C. on low fire). I don't have a Magnahelic Gauge.
Marcas
