Hi all and thanks for having me. I purchased a house with an older 2002 windsor pellet stove, It worked good until it didn't. The convection fan stays on high when its plugged in (it didn't do that before) the auger doesn't turn (it did that before) and the ignitor doesn't do anything (I'm guessing that its not going that far into the cycle to ignite ) I disconnected the 160 temp switch (also bypassed it with a jumper) it is normally open as it should be. I bypassed the 200 temp switch and also tried to disconnect it is normally closed ...with no change. I put external power to the auger and it came on as it should I also powered the igniter and it seemed to get warm I didn't leave it connected very long. I tested and bypassed the exhaust temp switch along with the vacuum switch also with no change. again the convection blower stays on high (power on or off) the blower fan also works when powered on ( I disconnected the vac hose and it gave me a vacuum code ) .It has the dhc2000 controller any help would be appreciated before I buy a new controller Edit... The power light is flashing about 2 second intervals and the auger is 2 on 8 seconds off consistent.
