Should the gasket be replaced each time the convection fan is removed for cleaning? It's one of those fuzzy type? What else can be used for a gasket on the fan sealing surface?
Ejectr said:Should the gasket be replaced each time the convection fan is removed for cleaning? It's one of those fuzzy type? What else can be used for a gasket on the fan sealing surface?
Window glass gasket?????SmokeyTheBear said:Ejectr said:Should the gasket be replaced each time the convection fan is removed for cleaning? It's one of those fuzzy type? What else can be used for a gasket on the fan sealing surface?
This is the convection blower correct?
If so you can just reuse what was there if salvageable or you can substitute a window glass gasket, they are sticky on one side so it is easy to get things back together no need for three hands.
Ejectr said:Window glass gasket?????SmokeyTheBear said:Ejectr said:Should the gasket be replaced each time the convection fan is removed for cleaning? It's one of those fuzzy type? What else can be used for a gasket on the fan sealing surface?
VTrider said:I also have a Windsor, I don't ever remember seeing a convection fan gasket? I had the whole thing apart last Fall as well, the convection fan is housed in a metal rectangle box/shield underneath the stove - is this what you are talking about?
Ejectr said:Wonder if one made out of this stuff would be OK.
http://www.autozone.com/autozone/ac...&fromString=search&itemIdentifier=932231_0_0_
SmokeyTheBear said:Ejectr said:Wonder if one made out of this stuff would be OK.
That would do the trick provided it is the correct thickness and can handle at least 500°F, and yes you need a new one every time you mess up the old one.
