Ok, I’ve done some googling & some searching on this forum to see if there is a common answer to this question but I couldn’t find it. So, I’m looking to you guys to bail me out before I pull my hair out.
The Problem:
- Stove runs for approximately 10 seconds and shuts off
- Auger functions as pellets can be seen dropping
- Combustion blower is functioning because traces of ash can be seen blowing around
- Don’t know about ignition plug since it doesn’t run long enough to do the idiot test
- Once the stove shuts off, the board flashes 1 time every 2 seconds or so (not sure if this is an error indicator or not)
What I’ve tried:
- Removed all panels and thoroughly cleaned inside the stove
- Removed trap cap and cleaned exhaust
- Checked gaskets
- Checked to make sure I didn’t have the ash pot askew
- Checked to make sure damper was functioning (tried starting with damper in multlple positions)
- Tried starting in hi/low, manual and thermostat setting (BTW - I don’t have a thermostat connected)
- Tried all of the above with window open (just in case my farm house is really air tight)
Other facts:
- 2006 model Enviro set on factory supplied stand
- 2nd stove in the house works fine - fireplace insert
- No thermostat connected
- No fresh air exhaust tube (manual said this was for tightly sealed homes and my 1856 farm house doesn’t fit in that category)
- Exhaust vents to a T and up into my my chimney and is lined to the top
I hope this gives you the details needed to provide some much needed advice. Let me know if I’ve missed a detail you need for troubleshooting and I’ll reply ASAP.
Thanks all!
The Problem:
What I’ve tried:
- Checked gaskets
Other facts:
Thanks all!
