I'm not able to raise the heat setting on my Milan stove. I think the reason is because the control pad has been dying a slow death. It's pretty worn out, so much so that the power button is now showing because the control "pad" is completely worn out. If the hear is not rising, do you think a new control pad will fix the issue or would it be the actual control motherboard that might be the issue? I'm just not sure what to order. The power button is very finicky too. If I put a piece of tape over the power button it seems to work better.
![Enviro Milan setting wont change Enviro Milan setting wont change](https://www.hearth.com/talk/data/attachments/304/304190-8bfa167bebd2872590174b1bcf97bfac.jpg)
