Enviro M55 Tips and Tricks (and money saving ideas)
Jan 10, 2016
23
northern Arizona
I'm starting this thread to document some Tips and Tricks for operating and maintaining the Enviro M55 pellet stove. I've owned my M55 for about 8 years now and is used as our primary heat source.
Anyone can contribute to this conversation and I'll edit this first post with links if appropriate. If I get enough links I may organize them by topic. But for now, it's just a list.
Here we go:
-An excellent thread on long term ownership and maintenance by member Threerun is here:
https://www.hearth.com/talk/threads/new-enviro-m55-fs-stove-owner.61814/
-Replacing the tactile push buttons on the daughter board instead of replacing the entire board by member dana.r. It does require soldering/desoldering skills. My own contribution to this thread starts at post #12 with photos.
https://www.hearth.com/talk/threads/m55-cast-daughter-card.142436/
-Replace noisy bearing on convection (room air) blower by me (post #2 below in this thread):
https://www.hearth.com/talk/threads...s-and-money-saving-ideas.175587/#post-2362655
-I was having repeated start-up failure with a flashing #3 light. This indicates the exhaust temperature switch isn't sensing high enough heat so the stove shuts down. This is legitimate when you run out of pellets but not on startup. I removed the exhaust temperature switch and cleaned it up so the heat transfer to the switch is better. This solved the problem with failed starts.
-Not hard to find with a Google search, but here is a link to all the manuals that Enviro publishes:
https://enviro.com/media/manuals/
Regards,
Marc
I replaced the outer bearing on my convection (room air) blower when it started making a lot of noise. I didn't document with photos, but it's wasn't a difficult job if you have some mechanical skills.
The bearing I used is an NTN Bearing 608ZZ Single Row Micro Ball Bearing, Normal Clearance, Steel Cage, 8 mm Bore ID, 22 mm OD, 7 mm Width, Double Shielded found here :
https://www.amazon.com/gp/product/B003MUJYAC/?tag=hearthamazon-20
