I have a 2011 Enviro M55 Pellet Stove. If you run the stove on Hi/Lo or Auto, it turns off after about 20-25 minutes and flashes the #3 error. Similarly, if you run it on Manual at heat level 1 or 2, the same thing happens. However, if you run it on Manual mode on heat level 3 or higher, it runs perfectly fine. Running on Manual on heat level 3+ is way too much heat. I know there is an issue with either the thermostat and/or the balance between pellet drop and air intake, but my noob brain cannot put it all together. Thank you for your help!
