Could someone with the new version blower tell me if their stove ramps the blowers to heat level 3 when you shut it off? Mine used to do this. If the stove was at heat level 1 and I turned it off, it would ramp the blowers up to about heat level 3 to cool the stove down quicker.
It has stopped doing this. Now, whatever speed the blower is on when I shut it off, it stays at that speed. I seem to remember it changing this behavior about the same time I installed the new turbo blower. I'm trying to figure out if I have a control board issue, or if this is normal with the new blower.
Also, even with a clean stove (totally, including the exhaust pipe and ash traps), I can barely get the magnahelic to register over .17 even with the damper all the way open. I'm starting to wonder if something happened to the control board and it's not putting the correct voltages to the exhaust motor?
Flynfrfun
Flynfrfun
