Hi guys and gals. I have an Enviro M55 cast pellet stove that we've have for about 5 years. About a week ago it developed a problem I've been able to figure out yet.
What happens is that while running the stove in manual, it randomly switches itself back to heating level 1. For example, I may have it set at heat level 3 and then after a day or two (or a few hours) it will switch itself back to 1.
Another interesting bit of data is that when it does switch itself back to heat level 1 it also goes through a startup sequence. If I switch it to heat level 1 myself it doesn't go through a startup sequence.
I started going through all the wiring and I did find that the cable that plugs into the "daughter board", which is the board with the control buttons on it, was loose. I re-connected that cable and I thought I fixed the problem because it ran 2 days straight without a problem. But today it switched back to heat level 1 by itself again.
I've called our local dealer who is a good guy but doesn't have a lot of experience with this particular stove. I'm trying to avoid buying a $300 mother board or a $150 daughter board.![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Regards,
Marc
Regards,
Marc
