Had an Enviro Empress FS installed last year in Nov, in a recently bought old farm house. In southern NH, and being our first year we only burned through 1/2 ton. This year should be a great deal more I hope in an effort to combat last year's oil expenditures. It was professionally installed and setup by our local dealer. No complaints at all for the first winter.
Present day, just had it professionally cleaned and shortly after they fired it up and it was burning along, the stove gave off a green flash and shut off. Got them to take a look, and sure enough the control board fuse had blown. There had been some pellets left in the hopper over the summer (I know...), but I'm about to replace those before I swap the fuse and give it a second try.
The fuse I took out is a Lf 5A/125V : UL CSA 235. I was able to find the same dimension/spec fuse at radioshack (5-Amp, 125-Volt, radioshack link).
The guys doing the cleaning offered to replace it for a $95 the next day, and the enviro dealer sites I see list the part as 50-833 (5-Amp, 115V, woodheatstoves.com link ), and are looking for ~$24/2 fuses.
To confuse the matter further, the manual states "Circuit Board 5 Amp Fuses - 220V (Pair)".
I do not mind buying them if there is actually a difference that makes a difference, but on the same token don't want to blow an expensive fuse just to find out something else needs repairing in the unit that a less expensive fuse would also tell me.
Does anyone have an experience or thoughts on this. My inclination is that the fuses I picked up at RadioShack should be fine, but I'm not an electrical engineer. I'm about to call one next to get some further insight as well.
Just signed up, this forum looks great![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
