hi, I have an empress fpi, i hooked 110 to all motors and they all ran. I also hooked 110 directly to the igniter and it gets orange. the stove was working but ran out of pellets which its done many times before. it did need an annual cleaning which I did. Im very mechanically/electrically inclined meaning i didnt leave any wires off etc. Ive checked the vacuum line its clear and the vacuum switch is working 120vac on both sides of switch. Im now leaning towards the auger maybe. it seems to make noise but im not sure if its jhammed. not many pellets if any seem to come down(it used to make a strong clinking noise before) my board has one fuse which is good. I start it up with the daughter board let it go through its cycle and it shuts down with #3 flashing. i checked low temp sensor cleaned it but stove is never getting that hot. when I first had the problem you could see some action and sparks in burn pot but now nothing. Im not sure if i checked for ignitor being orange during nortmal starting procedure(pointing to board?) I know it gets orange with 110 directly to it. its about 3 years old and has run great since new.
please help with any ideas? how does the auger come apart? maybe i could check resisrtance on auger motor? anybody have that spec?
