For Sale Enviro Empress Decorative Cast Iron Wood Pellet Stove - 35k BTUs 1600 sqft heating capacity. $1695.00
Don2222
9,188
Salem NH
Keep warm in this cold weather! This refurbished Canadian beauty made by Sherwood Industries has the heat you need and has that elegant look! The latest Enviro digital control panel with 5 heat levels has both Auto-On/Off for spring/fall and Auto-Hi/Lo for cold winter modes! It has a 55 lb hopper. At 35k BTUs it will heat 1,600 sqft or more with ease. Many new parts and high quality graphite impregnated fire door gasket. Professionally cleaned and lubricated.
Contact Don - 603-553-7402 Salem NH
This is for Local Pickup or Local Delivery for $75
Description:
A great stove for a home, workshop or family room.
Features:​
  • Efficiency 83.5%
  • EPA Tested 1.7 g/hr emissions
  • Full shaft with top and bottom bushings
  • 45-degree drop tube
  • Run quiet convection system
  • 105 cfm variable speed fan
  • 35,000 btu input
  • Easy access to slider damper
  • Ash pan latch
  • Air wash built into body of stove
  • 400w ignitor
  • Free-breathing firebox for more versatile operation
  • Cast iron brick liner
  • Easy-to-use controls
  • -On/off thermostat compatible
  • -Hi/low thermostat compatible
  • Cast iron doors that open
  • Levelling legs
  • 55 lb. hopper capacity
Manufacturer Specs
Model:​
The Empress FS​
Fuel:​
Pellets​
Thermostat:​
Optional​
Capacity:​
1600 sq. ft.​
Efficiency:​
84%​
Max BTU:​
35000​
Hopper Size​
55 pounds​
Type:​
Stove​
Width:​
26.5"​
Style:​
Traditional​
Height:​
27.5"​
Construction:​
Cast Iron​
Depth:​
26"​
Ignition Type:​
Automatic​
Weight:​
230 lbs​
Color:​
Black
[Hearth.com] Enviro Empress Decorative Cast Iron Wood Pellet Stove - 35k BTUs 1600 sqft heating capacity. $1695.00
