Hello!
I bought my house in May of last year and it came with an older enviro EF3 pellet stove. I had an enviro M55 for 5 years in my old home, so I am somewhat familiar with the operation.
I used the ef3 in the last burning season and it worked okay, but there were some issues with airflow to get a clean burning flame consistently. The damper only moved about 2.5 inchese from open to closed at that time.
Anyways, I decided to completely disassemble the fire box and give everything a good cleaning. I added a new ignitor, combustion blower, and convection blower to get everything moving like new again. I also have full movement of the damper now.
The issue I am having now is the auger will either come on at startup or not come on at all when starting a fire, it's hit or miss. When the auger doesn't work at all, the green light is illuminated constantly, rather than off/on when feeding. I triple checked that the wiring has been reconnected the same as before.
I read some old threads on here about bypassing each of the sensors and bridging wires to troubleshoot the problem, but I haven't been able to narrow it down. For example, I bypassed the vacuum sensor and the auger still didn't activate. I hooked it back up and the auger turned on for one startup, oddly enough, but it stopped feeding after a short period of time and the green light stayed on. The auger does work when wired direct to 110v. I cleaned out the vacuum sensor port and tube, there were no blockages or tears in the tubing.
I'm wondering if anyone has experienced this with their stove and has any suggestions?
Thanks!
-Shawn
Thanks!
-Shawn
