When I push the start switch the indicator lite would come on for a moment and then go out as it normally does and would light when the auger moves . Now the auger will not work. I have done the following,I have checked the circuit breaker with a multi meter for continuity and jumped out, the vacuum switch I jumped the switch, I connected the auger direct to 110 volts and it worked, checked all connections, jumped the timer as the manual suggests and it didn't allow the auger to run continuous after jumping the timer and reconnecting the two wires back to the timer the green indicator light now stays on as if the auger is working , jumped the temp sensor, I wold like to know what you folks think for one and can the timer and the other electronic box be tested on its own as in totally disconnected from the pellet stove. Thank you in advance, Wes
