Hi all!
Every year I spend an entire day taking apart and cleaning every nook and cranny on the whole stove, usually before starting my burn season.
However this year I did it late with a month left of burning. The entire season, I’ve been able to run the stove with the heat zone knob at the line above the “blue zone” with 0 issues. After cleaning however, the stove continually goes out (no matter what the damper is set to) unless it’s almost at the midpoint (pictured below is the absolute lowest I can get and still requires some babysitting). This is especially frustrating at the end of the season when I’d like to run it lower and save some pellets.
This is the first time I’ve dealt with this after a complete tear down and cleaning and I’m at a loss for what to check or fiddle with to get it back to it’s usual abilities.
One major difference with my cleaning this year was that I applied wd 40 and got the damper to actually be able to pull in and out- in the 4 years I’ve lived here it’s always been absolutely stuck in one position (fully open). Now it moves freely but doesn’t seem to matter much when I set it to the lower heat zone.
It’s often going out with a basket full of unburned pellets, and it’s a little harder to light at the beginning than normal (the igniter has never worked on it, so I always light it manually).
Any advice or thoughts would be super appreciated!
