The following is based on real world experience. If you are having issues with feed or flame please check your auger motors. Read on.
I purchased a model 25PI Insert Pellet Stove from Lowes in Feb 2003.
I have burned just under a total of 3 tons of pellets in 5 heating seasons. As you can tell that is not a lot. It is not a heat source for me.
In Oct 2003 I had to replace an auger bearing block.
In Oct 2003 I had to replace an auger motor.
In Jan 2004 I had to replace the blower motor.
In Sep 2005 I had to replace the other auger motor (still original not replacement above as the stove has two).
In Oct 2005 I had to replace the auger motor that was replaced in Oct 2003.
In Dec 2008 - I HAVE TO REPLACE ANOTHER AUGER MOTOR.
Thats a total of 4 Auger Motors, 1 Bearing Block and 1 Blower Motor.
In every auger failure i check leads to motor with DMM and confirm control board is supplying proper voltage. In every failure i swap the two motors (to make sure the problems follows the motor ) in case the control board cant supply enough current even though voltage is okay.
I called Englander 3 times over the last few weeks and nothing they can do but ask me to spend $130 for another auger motor. They also didnt seem interested in seeing what the root cause of the failures were (ie poor design vs the way its being used). Based on my limited stove use, I would suggest design but it wasnt a conversation they were interested in. No interest in having me send the defective unit back for investigation. Englander says "we all use the same motors". I see similar looking motors in other brands but based on my research Englander is the only one using that basic motor design at 1 RPM AND CCW.
My Design opinion based on thorough investigation, they are failing because of the windings are shorting out when the motor heats up. I have seen some posts about adjusting settings on the board if the flame goes out. I know from personal experience that my auger motor will fail after 3-5 hours of use. Windings will get hot, they will fail, auger stops turning and flame will go out. When stove cools down enough the failure will stop and motor will resume working. In some cases if the stove has not cooled down enough to turn off the auger will sometimes resume working and all of sudden the burn pot will be full of unburned pellets. Before you change you burn settings make sure this isnt happening.
Some advice - if Englander reps read this please act on it. The design where the winding wire meets the contact/plug is crimped. One time i was able to repair a failed motor by soldering the lug to the winding. That failure mode was intermittent contact between lug and winding wire.
Im faced with spending another $130 for a stove thats for casual use. I offer this all up both out of frustration and also to let others learn from my experience and hopefully not make the same mistake i did.
To quote their website and founder ...... "Ron England believes - as his father did - in making available a quality product ..."
Its looks like quality does not apply after the first year. Englander doesnt make the auger motor but my opinion is they are responsible for specifiying the design and life reqiurements to their supplier . The Englander name is on the stove and not the motor supplier. I guess as long as Englander doesnt need to cover the cost of the replacements parts they arent motivated to understand why this is happening.
If Englander reps read this and would like to contact me please do so via email. I keep meticulous records on the pellets i have used and i also have all my email correspondence with Englander dating back to 2003. I would be happy to work with someone to investigate why this happens.
Happy New Year
Happy New Year
