My Englander PVDC-25 (mfg. Oct. 2005) has started shutting off after running for hours. Here's the deal:
The stove will enter start-up, and I'll get a fire after 5-6 minutes (this is after a thorough cleaning of the igniter and tube). So far, so good. Then, I'll get an E-2 after 20 minutes, and it enters shut down mode. The room blower does not come on.
So, I push the "Start" button again, and after about 10 more minutes, the room blower will come on, and the stove will work just fine for some random amount of time.
Then, 1 of 2 things will happen:
1. The stove will just shut off WITHOUT entering shut down mode: Everything shuts off at once - room blower, exhaust blower, both augers, control panel. And the fire burns merrily away in the now-quiet room.
or ...
2. I'll get another E-2 and it will enter shut-down mode
Here's what I've done (just the recent stuff):
2011 - replaced bottom auger assembly (nylon gasket and auger collar), burn pot and wear plate
2012 - replaced top auger motor, replaced door and window gaskets
2013 - Replaced bottom auger motor
For this particular problem I have -
• Checked heat sensor (nice and tight at panel and firewall, and correct diagnostics)
• Checked all other diagnostics - all fine
• Checked factory settings (according to Englander, they're correct at 6-9-1 for this make and year)
• Thoroughly cleaned inside the stove
• Cleaned the inside back, including vacuum hoses
• Cleaned the exhaust pipe, outside air intake and flue
• Cleaned blowers in situ (did not remove them).
No luck. Englander help says factory reset may help. Do I need to tear the whole thing down and take a wire brush to it?
or ...
