i have had issues with this stove on and off, but it seems as though when i clean it, it struggles to get going. It will light but then shuts down with an e2 code.. Then it will do e2 code a few more times before it gets going... Any ideas?
Check your bottom 3 settings. Make sure they read 641. Also make sure your feed rate is set to 5 and blower speed to 1 when starting up. Then after start-up adjust accordingly.
Sometimes on a cold start I have to go through 2 startup cycles because ignition occurs later in the startup.
