englander pellet stove
Donzigypop
4
michigan
Please i need quick help. Im In Michigan its cold and my pellet stove is working but it will NOT come out of Start up mode. I have the settings on the lowest they can be and its feeding pellets into the burn pot like crazy. i have to keep shutting it down.
I doubt you will get many responses since you posted in pellet review section.. might try reposting in the correct location.
You may want to add as much information as possible as well. Otherwise its nearly impossible to diagnose anything. Good luck
In the correct forum, members may have you "calibrate" the controls. It seems easy, there are certain values for each lower button in this mode. Like A B D or similar.
