Englander pellet stove 10-cpm
Welcome to the forum
What do you mean by "jumps"
how long does it burn before going out?
How tight is your fire pot? My USSC 6039 fire pot would "jump" sometimes when the stirrer wedged a pellet between stirrer and pot. When clinkers formed stirrer would sometimes catch on one and lift pot then it would slam pot back into place. I added a bent piece of 1/2 flat stock to the side and it hasn't done it in last 17 years.
[Hearth.com] Englander pellet stove 10-cpm
It seems to go out shortly after startup. All Pellets are burned and burn basket is empty.
Check Vacum switch
This unit is equipped with a Vacuum Shutdown Switch (Part # CU-VS), which helps controlvarious functions of the unit. If an operational error occurs in the unit, a switch will stop the feedauger. Situations which could cause this include power failure, Combustion Blower failure, improperflue installation, a blocked flue (from rodents, nests, etc.), or “dirty burning” from burning improperfuel (see “Important Information” at the beginning of the manual).
Reactions: ARC
