Hello!
So the weather is starting to turn cold, and I figured I better get it in gear and get my stove ready for the burning season.
The short version of my question is... I tore my stove apart for cleaning and once everything was back together it throws a
E1 error on startup. ON powerup the combustion motor starts {seems like good air flow} and the augur motors are turning.
The stove then shuts down in less than 20 seconds with the E1 error.
More detail
- Since this is the third season I have been using this stove, I thought it would be a good idea to replace most of the seals of the stove. I purchased a gasket kit for my Englander pdv-25 stove. Side note...Englander is running a decent early bird special at the moment {http://www.englanderstoves.com/store/25-PDVC_Parts.html}
I then pulled the combustion motor {and housing}, room blower, lower auger motor & screw, burn pot, and disassembled all vent pipe sections. I proceeded to clean the everything everything well. Meaning wire brush parts/ blow out motors with compressed air/ vacuum / etc. I also went through the entire stove and cleaned every nook that I could get to with a vacuum.
After this, I replaced all of the seals/gaskets and reassembled the stove. I also replaced the seals on the stove door for good measure. I also went through all of the vent pipes and cleaned them well.
Once this was completed, I tried a simple power up to verify the parts install. The combustion motor and augers are both turning. To my
surprise, the stove quickly powers down after 20 seconds. This is with the door closed, and a fully connected stove. Meaning vent pipe connected/etc.
I may have missed something, but I have a feeling that I bumped something during cleaning and I am just missing it. Any thoughts/insights would be appreciated.
More detail
