Goodmorning;
I had trouble before with my stove and Mike from Englanders helped me get it running a couple weeks ago. It has never run this good before now.. I put Okanagan pellets in it and it has never run better ,It puts out tons of heat and a really great flame. Its feeding pellets with no problem at all. The combustion fan started making noise a couple of mornings ago so I oiled the bearing on the motor and it stop making the noise. The stove just won't make a fire now for some reason. It will start really well and burn good for a few minutes but soon after will smoulder down to almost going out. If I open the door a crack the flame jumps up for a few seconds when the room air hits it. I turned the stove off and let it cool and pulled everything apart I vacuumed behind every panel that isn't welded on and tried it again. Still getting the same thing. Starts great then the flame dies right down to almost nothing and barely stays lit. I checked the 3 windows at the bottom of the control panel and its set to 1 5 1 . I don't know what that means but during my searches it seems to be relevant .I have seen other people with it set to 1 4 1 and was wondering if I should change my settings.
Thanks in advance for any advice, Pete.
