- Oct 3, 2007
- 1,539
Hey everyone-I was at Home Depot the other day and took a gander at the stoves. I had put the idea of stove off for a while after buying the new house because of the cost of building a hearth (and because our living room is a little on the small side as it is), etc... I like the idea of the Englander add-on (I have forced air oil heat) though. I have a lot of questions as far as installation though because I want to be sure that I'm not missing any major cost/design/install issues. First is the cost of the stove itself. Online it's listed for $1600 and in the store the price was $1300. In searching old posts from as late as April 2007 I read of folks who had picked this stove up for $400 (half off), so I guess demand has risen quite a bit since then. Should I maybe wait for the price to come down? What time of year does this typically happen? I would imagine that most people who are going to install a stove have done it by February-should the price have dropped by then if its going to?
Next, as mentioned, my home is a 1200 SF ranch with forced air heat. I have a "fan only" option on my oil furnace, so I intend to use this to circulate hot air from the stove through the house. The stove itself says its rated for 3000 SF-is there any reason for concern that the stove might actually be too big for my home? I'm hoping that the layout of the basement will be conducive to installing the stove. There happens to be a window very close to the furnace itself, so I'm hoping that I can place the stove directly below the window, running the chimney out of there via a 90 degree elbow. I was going to buy the Duravent kit from Home Depot for running the pipe through the wall, etc... The window is rectangular, so I was thinking of simply blocking it up around the thimble with masonry-should this be acceptable as far as code? The hot air duct should be easy to connect to the furnace, but just to clarify-the plenum is the duct work that sits directly on top of the furnace correct? The chimney itself is the next issue. The window where I intend to bring the chimney out happens to be right next to the masonry chimney for the oil burner. If I run the wood burner chimney right next to it, does it need to be higher than the masonry chimney or can it be the same height? Is there any good reason NOT to run the wood burner chimney right next to the oil burner chimney? The two chimneys would sit about 18-20" apart.
Now-how about coal? I understand that Englander used to advertise this stove as a coal/wood unit but discontinued that advertisement due to folks thinking they could burn coal alone in it. I realize that the stove is meant to handle a small amount of coal once a good bed of hot wood coals has been established. However, in one of "Englander Mike's" posts he mentioned that the stove is meant to handle about 10lbs of soft (bituminous) coal. Would it be dangerous to try a smaller amount (5-8lbs?) of anthracite? Living in Northwest New Jersey I have easy access to anthracite, so I would prefer to burn it, but if I were only going once a season or so I wouldn't mind going further to pick up a few tons of bituminous. However, I do have about half a ton of anthracite that I got for free from an old house that was set to be demolished. My father and I had obtained permission to salvage some moldings and architectural stuff when we came across the pile in the basement. I loaded it in my truck and brought it home and it's been sitting in my backyard ever since. I'm grateful for any advice anyone can give me on this because the sooner I can stop burning oil the better!
) that I'm going to stretch as far as I can this winter. We both like it cool most of the time anyway are just as happy to sit on the couch with a blanket while we watch TV/pile on the down blankets at night with the house at 62 degrees. Next winter we may keep the house at a toasty 68!
