Hi All,
I moved into a new home with an existing 28-3500 that is installed in a 12x20 basement (a basement under an addition that is not connected to the main basement)
Blower is connected and ductwork runs to 3 vents upstairs and one vent to basement.
Chimney is 24’ Selkirk that runs up the north facing side of the house.
Flue design is 6” stove pipe rising about 1’ to a 45, to a 2’ straight, to another 45 into the chimney. No damper.
On my first couple burns, I noticed that when the stove got hot enough and the fan kicked on, my coals started to fade.
I figured that with the room being so small, the stove was starving for air, so I used a hole saw to cut a hole in my door leading outside and installed a 4” dryer vent with hose and directed the hose toward the stove. Problem solved.
I generally run the door vent about a turn and 1/2 open and the top vent 3/4 closed when I’m ready to call it a night.
I go to bed about 11:00, thinking that all is good until our family gets awoken at 2:30 by the CO detector.
At this point, we vent the house & I go to remedy the situation. What I generally find is a cold flue pipe and small chunks of wood smoldering in the fire box, with no smoke in the room.
I really enjoy having a fire to give me something to do while saving oil, but don’t feel comfortable putting my family at risk of CO poisoning. My wood is mostly maple, cut in Sept ‘19, split in May ‘20 and stacked in August. The wood burns quickly with no sizzle, but I haven’t checked moisture content. I haven’t measured draft, as I understand that taller chimneys generate more draft & I get a good draw up the flue after holding a lit newspaper at the rear of the firebox. I have my baffle pushed all the way to the back of the stove.
Sorry I’m rambling, but I wanted to paint a clear picture of my situation.
In short, I really want to be a wood burner and feel comfortable with my setup.
I was thinking of calling a local chimney guy, but through spending time reading posts here, I feel you guys know more about this Stove.
Looking forward to any suggestions you may have.
Thanks!
Thanks!
