Ok, got on of the reps right before close yesterday and control board setting "b" is the factory setting, we are trying at 6-4-1 on the lower 3 for right now. I took out the old wood stove 6" pipe that I had adapted this too (all 20 ft of it) and decided to run the venting directly out the back....through an old brick chimeny that is still there for some reason and out/up/ended! 3 ft horizontal, 3 ft up and capped. the old vent was full of ash and was fairly clean when I took the wood stove out/cleaned it.
Cleaned every knook and cranny, I had a new room blower so I just replaced the other and will do a service on that later. upper auger bearing needs replacing and will get that ordered but is working decently now. Exhaust blower only had 3 of the 5 screws in it and one was stripped, cleaned and replaced the screws, re-adjusted the oak cause it is now sitting directly under the mantel and is only 6" from the wall as opposed to 12 like before. The hardest part was drilling though/fixing the brick chimeny, it hasn't been used in 40+ years and was never capped, however it was kinda cememented off. I hit something and all 40+ years of "stuff" came running in the house/ out the hole I broke though outside. I have about 40 gallons of decomposed material, dead animals, bugs of all kinds just filling my house. Glad the wife was gone for the night. I'll get some pictures up soon. Hopefully this resolves the low heat issue!
