Hi all, newly installed used stove in my double wide. I did the horizontal through the wall 3" Duarvent kit and then vertical 4', followed installation instructions carefully. Also installed the Englander OAK, well away from the exhaust. Couple issues I'm having with the stove, hoping some advice will help me in the right direction.
Stove runs great, hot as heck when we use it. It was self igniting, but the last 4-5 fires it hasn't self ignited, just runs for 20 minutes and then shits down with an E2. Sometimes clean the pellets out of the burn pot and retry and it lights properly, sometimes I just use the map gas and a handful of pellets to move it along. Exhaust seems great, but I'm unsure of my outside air, specifically if I'm getting enough outside air. The glass is sooty after every burn and I'm getting what I think is a lot of ash in the pan and leftover in the pot. More of a yellow flame than a bright whiter colored burn. I've temporarily removed the weather cover from the OAK as I can see it being possibly restrictive. Apart from that, I guess pull the OAK off the back of the stove and get in there to make sure its free of any obstructions? Any other advice for that issue or the self lighter would be greatly appreciated.
This is a used stove, seems like its in pretty good shape. I do not know the seller personally but he seemed pretty good about doing maintenance and things like that, stove was VERY clean when I brought it home and a test fire in the back of my pickup worked flawlessly.
Thanks!
Thanks!
