Englander 25pdvc question
WoodPorn
1,503
South of the beloved Patriots
I know this question will be subjective but.....
Can anyone tell me approximately how much I will be burning per hour on my stove. Figure on settings 1 and/or 5. I have also heard you can modify the CPU to operate at a lower rate than factory settings allow, does anyone know of this mod?
P.S. I will be burning NEWP's if it makes a difference.
-Just wondering how much I'll burn............not rocket science!
Werm, talk to Mike he is great to help you out, depending on your set up you should be able to tweek to burn a bag of pellets in 18 to 20 hours easy with good heat output.
stoveguy2esw said:
you should be running about 1.75 lbs per hour on h/r 1 up to 4.5 on high, a 5 range is about 2.5 to 2.75 lbs per hour
Mike, I think I've spoken to you on the phone before, You and your team have been very helpful in the past, great c/s.
Is there a way to slow the stove down?
