Hello,
finally got cold enough to fire up stove for the first time, do not really need the heat now just wanted to do first burn when it was not so hot.
Well when I installed it and did the first dry run everything worked good, so finished the install and forgot about it.
Now I went to start it up by hitting the start button and noticed the bottom auger not turning, let it go for a few minutes and nothing, the igniter was glowing and so on but no auger. Read the troubleshooting guide online and it said if the motor was hot but the auger not turning then the motor was bad. I do not think it is jammed cause I can move the motor up and down a little and the auger turns in the barrel. But the motor is kinda hot.
Any ideas?
felt bad here cause the stove is new and never burned, never thought this would happen.
thanks in advance
Any ideas?
thanks in advance
