Perusing forums here and elsewhere, I'm wondering if the room air output temp on my Englander PDV is lower than expected. My setup is as follows:
After about a 3.5 hour continuous burn from startup at 8/8, the air temperature of the convection air coming out of the left most vent hole measures 127 degrees as measured 1" from the hole.
After about a 3.5 hour continuous burn from startup at 4/4, the air temperature of the convection air coming out of the left most vent hole measures 104 degrees as measured 1" from the hole.
Thanks for any insight!
- 25PDV
- lower settings 6-4-1
- Mode is d, (thought it odd for a PDV, but called Englander and they said the Default for a 25PDV built 08/08 is d)
- The side round 3/4" holes in the burn pot above and below the wear plate have been plugged w/ Hillman plugs as several folks on here have recommended.
- Pellets being burned are New England Wood Pellet.
