I did a full clean on a 25-PVDC to try and help out a friend getting better heat output. Vent was fully brushed cleaned. Conv and comb fans removed and cleaned. Compressed air used to clean inside the comb fan housing and inside the burn chamber to clean the heat exchanger. The stove still outputs more heat on the left side of the conv fan vent outputs than the right side outputs (when facing the front of the stove). I told him it is because of the design and the heat exchanger. That is, more heat comes out of the left side because that is where the comb fan is.
Others must have noticed this. Anyone modify the heat exchanger to get more output or evenly distributed heat output?
