Hello all
The wife and I recently inherited her great grandmother's house. For years she used a wood stove in combination with HWBB heat in an older farm house that has been updated. The wife doesn't want to burn wood so I bought a factory referb Englander 25 pvdc. I installed a new 6" thimble in masonry chimney and used a 6" to 3" stainless adapter with 2 adjustable 90* fittings and a 6" straight with the special stove adapter. Hooked up the OAK outside and sealed all of the pipe seams with high heat silicone. Oh, and I test fired the stove for 3hrs outside to burn off any paint. Stove seemed to run good on setting 5-5 and I turned it down to 2-2 after 2hrs.
Anyways, bought a programmable Honeywell thermostat to control the heat when I'm not around. I understand when the stat calls for heat it brings the stove up off of idle until it reaches called heat, then goes back to an idle. My question is does anyone know what prongs to use on thermostat, there is 8 of them and instructions don't help one bit. Guy at hardware store says its a millivolt setup and good for pellet stoves along with furnaces and heat pumps. I installed the wire (4 wire but only using 2) into the stove as directed but don't know what to use on the thermostat. See attached pictures and thanks for such a great forum.![Englander 25 pvdc hooking up thermostat Englander 25 pvdc hooking up thermostat](https://www.hearth.com/talk/data/attachments/136/136910-00f0304782822af3e5deb749ef840455.jpg)
![Englander 25 pvdc hooking up thermostat Englander 25 pvdc hooking up thermostat](https://www.hearth.com/talk/data/attachments/136/136911-a81fd883f02608fb4a4c880b4806fd64.jpg)
![Englander 25 pvdc hooking up thermostat Englander 25 pvdc hooking up thermostat](https://www.hearth.com/talk/data/attachments/136/136912-f1ee597230ec1757fa9dd38d0771fbe9.jpg)
